Globalti
parton84 said:I was cycling down a slight hill the other day in top gear with my legs going like billio, feeling like they weren't having an effect doing 30.6 mph, Surley I shoud be able to pedal faster than this. I will check my teeth tomorrow and get back to you's. Thanks for the advice so far guys
30 mph is pretty good for a hybrid or MTB. If your leg strength is growing you could fit a slightly larger big ring, which will give you a few more mph but be honest - how often will you ride that fast? Most of your riding should be in the middle and big ring, using the full range of gears. You could fit a wider-range cassette but this will only help you on hills as 11 is the smallest and all you will achieve is more overlap between the gears.
This website might help to explain: http://home.earthlink.net/~mike.sherman/shift.html
