Festina_Lente
- Algarve
Front break produces most of the breaking force, 70% vs 30% of the rear wheel I read somewhere. Look at the brakes on a car... the idea is the same. With corners, like any vehicle you break into a corner, accelerate out.
In a corner you might want to use it a little less vigorously as loosing the front wheel means crashing and this is most likely to happen while breaking, against when the wheel is in motion. The rear can be used to slow down in this situation, because locking out the rear rarely means crashing, just a skid, so it's safer.
Cycling and other momentum sports utilise "vision control" in order navigate at high speed. Practice not looking at an obstacle but where the obstacle isn't and as far down the road as possible. Don't focus on apexes but on the exit. This applies to breaking because you will need a space to slow down. E.g. in a group ride you need not break, but just turn gently away from guy in front. Never look at the ground in front but straight ahead, up the road and let your subconscious peripheral vision and reflexes take care of the rest.
Oh and no fear, fear originates most f*** ups!
