It would be easier to make your bike, front wheel drive with the mech on the left and just convert it to rear wheel steering.
iv thought of that but i think a delta trike with that method would work best as in my experience rear steering is a bit tricky on the roads, and best suited to a trike im thinking of doing just for off road with suspension front and rear and having rear steer for manoeuvring around trees and tight turns
I've seen the stuff you do in other threads, and am amazed by your skill and ingenuity,
thanks but i think its more luck than skill lol you dont see the 20 attempts that failed loln
If I understand it correctly, the only thing as proposed that is unusual and on the left is the triple up front, driving a single on the left in the middle (presumably there is a tensioner), which drives directly another triple at the middle this time on the right, which in turn drives a conventional rear train again on the right as normal.
The challenge of that is if the front mech for the front triple is mounted upside down (so that it is on the left) it will be facing backwards in terms of chain direction since it has to be rotated 120 degree to derail the driven/upper chain.
If I were you what I would consider is to keep the triple in front on the right and let the chain drive the inner or outer ring of a triple/quad* chainset at the middle again on the right, leaving 2/3 rings driving the rear conventionally. You will having to play with bb/chainring spacers/bolts to ensure no clash between the two chains, but it is simple, cheap and should be efficient.
* via a triplizer ring e.g. With a trike I would have thought you have quite a bit of freedom re chainline.
i think i have confused most folk on here what im thinking is getting a standard rear section of bike with gears chain pedals ect then remove the pedal on the left and fit a single gear this would be driven by a second bottom bracket on the left at the front and i was thinking of using a old rear deraillier to provide tension on the chain so its just changing the gears on the front triple.
i have been thinking of turning the derallier upside down and then maybe making new chain guide arms. it seems to work but im not sure how to make strong enough guide arms,
Stuee,
Could you just put tandem gear on it to avoid the crossover with another compact chain ring on the pedal set to get an extra set of gearing ...shouldn't have any worse drag or friction than a tandem set-up would?
iv never thought of a tandem gearing ill have to look at that iv no experience in tandems yet lol
i did have an idea last night i thought maybe try and make up spacers and bolts to fix a 4th gear to the triple on the rear half of the trike that will still give me what im after with the normal, extra low and extra high gear sets but all the gearing and chains will be on the right it should make it easier i just need to work out where the chains will run and how far out it will be under the seat. its just another idea iv had but i always look forward to anyone else's input
stuee
