I had hip replaced Jan 2021, was back on the road in May, doing 50 mile rides in September. Completed 2000 by the end of the year. I know several others from the club who've done the same. Then again we're all different. The cautions you were given generally apply for the first 6 weeks after the op, which is appropriate.
Can you do the obvious things like put your socks on as you would have before the op, can you pull the operated leg up to your chest pretty much as far as your other leg? If so, unless the advice given to you was specifically due to your paticular medical condition, you carry on cycling as before. I started with 10 minute gentle rides on the flat then built up to 5 then 10 then 15 etc., being sensible about the effort I put in. I did start on the turbo after 6 weeks and did a couple of minutes with no resistance turning my legs slowly and gently then increased to 10 mins over a couple of weeks. It was so boring that I rode up and down the road after that! Drop the bike down and put your leg over gently - you don't need to raise your leg that much.
Most importantly stop if anything hurts, do everything gently to start with. What works for others may not work for you, your body will tell if it's not right. Good luck!
I can't do them, being an ex, but still festering needle phobic. That's why they said they'd send a district nurse to do it.
I can only take injections by not looking at them. Injecting yourself with your head turned away isn't wise i'd say!
