GuyBoden
- Warrington
I think one of THESE should enable my rear mech to cope.
@GuyBoden - which sprocket did you take out to make space for your 42? I saw a suggestion to remove the 17 but that would probably be one of my most used gears. I'd be tempted to remove the 13 if I could. That way I could do most of my flat to fairly undulating riding on the big ring and only do the big jump from 15 to 11 on the rare occasions when I wanted to/was able to ride at 40+ kph (25+ mph).
Colin, I removed the 11T smallest sprocket. It was the simplest solution, as I rarely use the 11T sprocket.
Also, it's a very simple task to fit the 42T sprocket, if you have a 10 speed cassette, because the spacer rings are provided with the 42T sprocket. Other size (9) cassettes will/may need different size spacers.
As you know, a long cage derailleur would make fitting the 42T easier, but I managed by adding an extra long B stop screw to my medium cage Deore. Yes, the Derailleur Hanger Extender seems a good idea.
Have fun.
