ColinJ said:![]()
That hill is just down the road from me. It doesn't take much of a calculation to work out that its average gradient is only about 3.3% but it does have a short section in the middle which is probably more like 7%. Still not a leg-breaker, but when you are not fit it can feel quite tough.
I went from using a 30/23 gear on that section to using a 39/19 in about 6 months, merely by riding a lot and losing about 2.5 stone in weight. My cadence was the same in both cases, I was just riding a lot faster when I was fit!
I surprised myself actually - I thought that I was on my small chainring and was just using a smaller sprocket, but once I'd cleared the steeper part of the hill and looked down, I realised that I'd been on my middle ring the whole time.
So what I'd say is - keep on riding and lose that weight, the rest will follow!
If you're out of breath and your legs are burning, you are trying too hard, knackered, unfit or some combination of the three!
jimboalee said:And when you've been riding for a while, your gritty determination will force you to ride up the hill on a higher gear, effectively 'grinding'.
Oh it will hurt, but as your leg strength grows, the gear will get higher, as will your gritty determination.![]()
jimboalee said:Warm up and then get the bike to 18 mph on the flat ( on a windless day ).
Flick the bike up and down the gears ( maintaining 18 mph ) until you find a gear that is comfortable for riding at this speed for the next hour.
I can't find one of those; do you know where I might buy one?
Unfortunately, I have a dodgy left foot and a dodgy right hip which both give me problems when I usejimboalee said:Shifnal Station - Shrewsbury - Llangollen - Ponderosa Cafe - Llangollen - Shrewsbury - Shifnal Station.
100 miles round, Llangollen to Ponderosa avg 4.5%, last 1.5km is 13%.
A 1970s 'training' ton. On my Pug with a 38 x 23 lowest.
coruskate said:If you're out of breath, you're spinning. If your legs are burning, you're grinding.
Wigsie said:Jimboalee will be along shortly to give you a cadence equation.
Randochap;745998][quote=jimboalee said:Warm up and then get the bike to 18 mph on the flat ( on a windless day ).
ColinJ said:Unfortunately, I have a dodgy left foot and a dodgy right hip which both give me problems when I usebrute forcestrength to climb, rather than spinning lower gears. I might get up steeper hills using higher gears but then I'd have to pedal home using one leg and not be able to walk comfortably for days...
I did the East Chevin climb out of Otley last weekend. That's 10% for 1.6 km and I found that a bit of a slog in 39/29. Mind you, I'm still about 35 pounds overweight. I think I'd be reasonably okay on that in 39/23 if I was slim again.
I nearly always climb sitting down. When I do climb standing up, I usually change up a couple of gears.
jimboalee;746925][quote=Randochap said:Come on a trip to The Vale of York.
zacklaws;746990][quote=jimboalee said:I hope you mean that between where you live and the Vale of York there is some hills to pedal up to get there, as the Vale of York is flat , bordered on the West side by the Yorkshire Dales and the other the North York moors and the Wolds. Both together renowned for there hills to cycle up.
Most of my rides take me up onto the West side of the Wolds whereupon I look West across the "Vale" with all the flat land stretching away towards the Pennines with no noticable hilly features.
As Rigsby in "Rising Damp" would say, "There's nothing between this house and the Urals. You're breathing the same air as the Tartars - I should charge you extra"
