oldgreyandslow
- Farnborough
I previously posted a question about changing the gearing for hills, at the time I had a 12-25 / 34-50 combo and had bought a replacement rear cassette which was 12-27.
I had this prior to posting and some folks recommended changing to a 12-28 rear, however as I had the 12-27 already I decided to see how that worked and surely 1 tooth isn't going to make that much difference is it?
As I am "lucky" enough to have got a spot on the ride London 100 and I'm somewhat concerned about the climbs of Leith Hill and Box Hill I ned to up my game. I know the best way to get better at climbing hills is by climbing hills and I have some relatively short ones nearby. One I have tried a few times rises 135 feet in approx 0.6 miles, but is quite steep nearer the top, my problem is that it's a slog to get over it, sometimes its not so bad others its a right pain and I max out at 168 bpm on the HRM which clkearly isn't sustainable.
This hill clearly doesn't compare in length or steepness of the ones I am likely to encounter, however I was hoping that doing enough reps on it may improve things to an extent that I could stand a chance of not walking them.
Distance wise I'm not concerned, I regularly ride 60-70 miles on undulating roads and upping the distance I think is doable.
So the question really is how do I get better at climbing so these hills won't be a huge problem and as a side issue should I give a 12-28 a try? I know I'll need a couple of extra links in the chain.
(that's me btw not the OP)
no wonder you cant understand difficulty in getting up hills you young whippersnapper!!
