T4tomo
Right so I set up my old Hifi Separates last night. Its nothing fancy, based around a Cambridge Audio azur amp.
Turntable & amp were perfect, I was soon blasting out Smoke on the Water, much to the OH's amusement.
The CD player (again Cambridge Audio) has a slight issue, in that when you open the tray it pops open but zooms straight back in again, so takes good timing to change the disc over , its possible, but not ideal and not a long term solution.
Question 1 - would this be repairable or is it in the just not worth it category?
Now bear with me on the next bit as it it may wander as much as a @wafter thread.....
I was also looking at options to be able to play Spotify through it. (I have a decent sound bar in the same room so I can bluetooth my phone into that (or 3.5mm jack connect my old ipad to that too, but the amp and speakers have more power and charm).
So first google wormhole was getting a blue tooth connector to the amp, I have a 3.5mm jack to RCA input cable so anything with headphone out I can connect to the amp. Amazon echo dots are a reasonable option apparently, we have the OH's in the kitchen, and you can bluetooth most things into a dot.....I dont have amazon music subscription, but do have a family Spotify account.
That then led me to integrated DAB / radio players and then onto some which also have a CD slot in the DAB player which then led me similar that also have Spotify connect built in, which is great because one SConnect is going it doesnt matter if you wander off at party out of bluetooth range it player straight off Spotify servers over wifi. (small aside I used to play my spotify over the OH's smart TV with SConnect, whilst out, particularly if she was in listening to Take That and then smile as she told me how spotify on the TV was playing up)
Question 2 - on the assumption that the CA CD is farked, anyone care to recommend a CD player that you can also bluetooth into as a minimum? Somethimg with Dab and / or Spotify Connect is a bonus. As a backstop the old Ipad jack plugged in the amp will take care of the Spotify and radio option by using BBC sounds / various internet radio apps. The battery isn't great on the ipad, but it can have the charger cable pretty much permanently plugged in if left sat on / by the Amp.
I don't want to spend a fortune, I don't have the hearing of a bat to fully distinguish between good and brilliant Hifi systems, I just want a solution to play CD's and have be able to somehow connect Radio and Spotify.
I did come across some Auna stuff that looked good, but some of the trustpilot reviews on customer service were horrific. e.g.
https://www.auna-multimedia.co.uk/index.php?lang=1&cl=search&searchparam=connect+CD
anyone any experience or alternatives?
