BADGER.BRAD
- Shropshire
“HGVs could be designed to operate safely in the city in the same way that London buses are; that would make sense. Continuing to run the most dangerous vehicles and suggesting that cyclists should be trained for their own survival does not.”
First off I think you will find that per mile travelled HGV'S are much safer than buses every year in the the Dudley Wolverhampton Birmingham area there are at least a couple of people run over and killed by buses normally old people, and then others injured.
Unfortunately the good old days of horse and cart deliveries are gone so HGV's are here to stay. With better planning from Shops and industry deliveries could be reduced by quite a large level , the amount of times I've been sent out with a 45 foot trailer with one or two pallets is amazing only to be sent to the same place the following day again with one or two pallets ( the super markets being the worst for this) Better street planning would help as would better lorry design. but for you to suggest that Cyclists wouldn't benefit from training is like saying we won't bother teaching children the green cross code as it's the cars that are running them over !!! Your digging a bigger hole for yourself with every post Dondare !
You need to look at the problem from a real life prospective, not just how you would like life to be.
P.s if the text was too small for you to read I suggest that you should have gone to Spec savers.
