stuee147
- north ayrshire
I may have missed something, but are not the seat and backward moving wheel going to get in each others way. Is will of cause still be narrower.
By way of a daft alternative. Put 4 casters on a bit of board with an old cushion on it, tip the trike on its side with 1 front wheel on the cushion. Then push it through the house like a df. Or just knock down part of your fence and g out through the woods.
your right the wheel that goes backward will touch the seat or the headset will atleast but i think it will be able to piviot enough to fit threw the door as its only about 2 inches to wide at the moment to fit. the idea is that the two frount wheels will still be facing forwards when folded so it would almost be 3 wheels in line (but obviusly not in a perfect line)
i did think of turning it on its side and using an old skateborde to bring it in but its taller than it is wide and with the pannier boxes its not as easy as it sounds lol heres a how my MK2 trike looks
This might work, be worth thinking about.
but switch it so that rotates about a 45 degree angle
You will need to lock it into place for when riding or it will tip you of
