No modification - you unscrew the rubberised plate then fit direct to the hope bracket. You may need some silicone sealant where the cable goes into the body (I would do this).
Yes, increases the diameter of the bar and is also rubber so grips the bar preventing slippage (wash off any talc as this will cause the tube to slip).
