Hi, New to the forum... and not used forums in a while, so hopefully these pic's will work.... anyway, I'll give you a brief outline of what the situation is, and any advice/opinions would be appreciated, anyway... a few of you have already said hello on the new members area, hello to the rest of you!
firstly, I havent been biking for a while and have been thinking about doing it for the last few months, anyway, me and the missus went to a car boot sale today and i came across a few bikes, on a total impulse i thought i would get a cheapo to make sure i would use it enough before putting real money into it.
The bike in question is a Giant Rock here is a pic for a rough idea;
It is a "bit" on the small side for me, but i hadn't thought that when i got it, (& thought i could re-sell it at a higher price anyway)
After getting it home (trying to fit it in the back of my corsa was fun!) and having a proper look at it, i located all the issues.... now this is when your gunna relise actually how much of an impulse the buy was!
Now, all these issues, although very annoying, seemed easily fixable, so, I've spent all day fixing what i could, adjusting brakes, cables, calibrating the derailleurs, removing the broke/naff bits, generally getting it to a state where i could ride it.... theres a few things i'm still to do (i dont have a bike pump - and the tyres are inflated, but nowhere near the PSI i will need to get it to - and i also need to pick up some cheap bar grips and a spoke tool for the rear wheel)
I was actually starting to get pretty proud of myself (after the initial "F"ing and "C"ing), considering my lack of bike maintenance knowledge...
anyway.... to the main point of the post.
I've come to the rear gears.... so firstly - i set the derailleur in the same fashion i did the front, the chain does not fall off anymore.... success! (or so i thought at least!) now to indexing the gears.... so, i had a read on how to do it properly and got started.... everything seemed fine, jumping from 1st to 2nd just fine, but then not to 3rd until i got a few more clicks up... so.... after some more "f"ing i started to calibrate it from scratch again.... this is when i notices something pretty wrong looking....
Here's the gear leaver......
The gear changer (if thats what its called)......
and the gears themselves.....
notice anything?
its a 7 speed changer, but it only has 5 gears!!!!!
needless to say i was pretty stumped/felt even more ripped off than before....
I guess the advice/opinions i want to get are.... is a bike like this worth trying to fix... is it the whole wheel that needs replacing, or just the gears themselves.... I'm guessing by the fact the changer says "7 sis" on it, that it is correctly matched to the levers, just not the actual gears.
Is this something that is affordable/worthwhile doing, and more to the point, will I be able to do this myself?, im not too keen on paying for expensive parts or for someone to fix a bike that i have bought for the pure reason of how cheap it was...
Will i need to know particular sizes if i go ahead with buying a part as i have no reference to go by as the gears are currently wrong anyway?
Is there anyone here from scotland know of any second hand parts places (I guess the main online auction sites may be a shout) but i hate waiting for stuff to be delivered! - I've heard about "recycle-a-bike" places that take donations/abandoned bikes from the city you see without wheels ect... i probably should check them out, but don't know if they do parts or keep them for fixing the other bikes they get in...
I'm kinda taking this as a life lesson in bike buying and will know exactly what to look for in the future when i decide to upgrade and spend a bit more cash!
anyway.... I know i said i was going to give you a "brief outline" but i can go on a bit! As you may have noticed! lol any comments will be very much appreciated!
Thanks,
Ross
- The V-brakes were very loose and squeaky... they could not stop me when i jamp on it for a test run,
- The brakes were also miss-aligned and rubbing/not allowing the wheel to move freely,
- There was cable ties tightly pulled round the open gear/break cables on the frame,
- The derailleur cage was not changing gear on the front sprockets, and the rear gears would come of and get jammed between the sprockets and frame if i took the gears to high, or low for that matter,
- The front gears plastic cover was snapped,
- The bar grips are foam ones, covered in electrical tape (and feel ripped under the tape)
notice anything?
Thanks,
Ross
