dmohalloran
Member
- Leeds
I've got a clunk noise which is baffling me. I wonder if anyone has any ideas?
The clunk only ever happens under seemingly specific conditions.
(1) I'm in the fourth cog at the rear (running 8 cogs at rear) - Not noticed in any other cog
(2) In small ring at front but more pronounced when in big ring.
(3)The clunk is felt in my shoes/pedals when at 5 o clock and 6 o clock in the revolution,
(4) It sounds like a clunk
When I put the bike on the stand and pedal in the above configuration, I cannot see anything which would indicate this.
All the gears are indexed and shifting is good, I've checked the pedal's removed and greased and reinstalled and lubricated them, also lubricated and tightened the cleats.
There is no lateral play in crank arms. I don't have a torque wrench but the bolts seem tight.
When searching the internet, can't seem to get any ideas. The Bottom Bracket might be suggested but surely it would be in any gearing, The crank arms might be suggested but there is no lateral play in them. It does not appear to be the chain or derailer as it is not consistent in other gearings.
My main concern is it is a sign of something bigger, but currently it is a niggle. I have cleaned and done everything in my mechanical skills to check it out. I'll hit the LBS if nobody has any suggestions. I'd prefer to fix myself as I can't be without out my bike as it is my transport to and from work.
I've got a cannondale synapse claris 8 2014 model with shimano m540 pedals if this makes any difference.
Any ideas would be most appreciated. Thanks
