chugsy
- Nottingham
Hi All,
I recently acquired a new commuter on the C2W scheme at work but have held off on using it for commuting until I got some Marathon + on it. I've never had presta valves before and had problems last night pump up the tyres beyond 50 psi. I use a screw on presta/schraeder convertor valve and a Zefal Rush Plus trackpump. It does not have a locking lever at the head, just a spring loaded clip which grabs the side of the valve. Pumping is fine up to 50 at which point air starts blowing out with each stroke although it is possible to continue pumping. Anyone have any tips or is it time to bin this 10 year old pump? Feeling a bit skint TBH after being forced to upgrade tyres on a new bike
Also, any tips on using external pressure gauges? My cheapo digital gauge from tescos works great on normal schraeder valves but I can't stop the presta valves (with convertor) from loosing air as I hold the gauge over it - don't know if this alters the readings or not
Cheers
Cheers
