U
User6179
Knew it wouldnt belong before you got personal B nY!
Good nite
Good nite
No one is disputing that fitness is the biggest influencing factor by a long long way, but as posting links to more experienced riders comments extolling the virtues of good hill climbing technique makes me "disappear up my own arse" Can you explain why you referred to "sensible advice" in relation to hill climbing then argued that it wasn't "technique" which is semantics. Why was this "sensible advice" implying you should do it, and yet you argue that it will make no difference to your climbing speed. To quote you "Gearing, cadence and position are all useful (if somewhat elementary) considerations while climbing" Surely two identical riders who have exactly the same fitness levels will end up at the top of the climb at different times if one applies their power in a more efficient manner on the road possibly by using a better chosen gear, a more appropriate cadence for their physiology and a good position. If not why do people tell you to do it?
This is a genuine non ironic question.
Oh and as you are so keen on this maybe you could show us some scientific data as to identical energy transfer while climbing in different standing positions and when seated.
One last thing if you could avoid refering to my arse and try not to answer in a Clarksonesque its all about the POWER type of response I would appreciate it.
That would not be about aero but more about body position.Aero is not much of an issue when climbing.
No aero's are quite light. A Mars would be more of a penalty.Aero is not much of an issue when climbing.
Aero Bars are the things for going faster ...No aero's are quite light. A Mars would be more of a penalty.
Think about where the power is measured. Both riders producing 300W at the cranks, but one may produce another 20 that he wastes in upper body motion etc. If he changed his " technique" to better harness that power at the cranks then the riders now have different power outputs.
Yes, the body kind of works that way ....Hang on, you think the human body works like the National Grid..? You think we can just divert 'power' from the upper body to the legs whenever we need to..?
It may well be good practice to do all of those things - but expecting it to actually make a difference to your speed (ie your power output) is fanciful.
You haven't understood what I mean by 'gearing' - a combination of your chosen gear and the cadence you ride at. It is possible for two riders with the same gearing (ie the same road speed) to have differing gear selection and cadence. Road speed is the only constant. Assuming that is the case, I can't see how technique will play a part.
No idea where to look for that. If you find some, post them up. Meanwhile, we'll all have to rely on anectodes - just like everyone else in this thread.
Unfortunately for you (and your arse), climbing is all about power - sustainable power, that is - as are most aspects of performance cycling. Technique is largely irrelevant, to the point where agonising over whether to get out of the saddle, or breathe more deeply, or relax your shoulders (FFS!) will probably have the effect of making you slower - because it will actually divert you from what you should be concentrating on, which is pushing the sodding pedals round in a circle.
