Hi
I'm a relatively newbie cyclist, been cycling since last August on a Pashley poppy, which has 3 gears and is horribly heavy and simply doesn't do hills.
I cycle up to 120 miles per week so been finding the pashley hard work for the last few months so I decided to buy a new bike with more gears and lighter.
I live in a district that is largely flat, has tow paths etc but also a hilly area fairly close by, so opted for hybrid a Specalize bike which does dirt and road. A week later (and it was certainly coming on while on the pashley), I have cycler's palsy so I went back to the shop. I have felt my body weight is very far forward. The shop say that the saddle needed adjusted to tip up..... my question....
I have long legs so they fitted me a large size, however I'm concerned that my arm length is too short for the bike frame (and this will require a confrontation with the shop). Right now I have a numb pinky and ring finger so I need to give it a rest before I re-try the bike with the saddle adjusted...
Is the saddle adjustment likely to fix the problem or is the frame size too big? How do I tell.... my arm length is about 60cm from wrist to central underarm... the bike dimensions are as follows:
Seat Tube Length - Center to Top 482mm
Top Tube Length (Horizontal) 600mm
Standover Height 622mm
Head Tube Height 130mm
Stack 646mm
Reach 415mm
I don't know enough about bike sizing to know if this is something the shop can adjust the bike to fit or if they have sold me a bike that is too big. The leg length feels right....
Help...
PS please explain any technical terms you use
Thank you for any help
Lis
Stack 646mm
Reach 415mm
Help...
Lis
