As above the use to which it will be put to, budget etc is useful.
As a general point I would recommend you choose from the top two as the Zelos, although cheap, has some poor components on it.
So the two left are a road bike and a gravel bike. A gravel bike will have chunkier tyres for unmade paths aand rough ground allowing you to go off the beaten track.
I should pop into
Halfords (Carrera is A Halfords house brand) and swing a leg over them, they might even let you take it around outside if you ask nicely.
It's very important to get the right size so I'm hoping there is someone in your local branch that can advise properly.Halfords staff can be a bit hit and miss.
Hello and
to CC
