I use a regular track pump (700x32c on 28mm wide rims), I haven't had any need to use anything else yet fortunately.
An alternative to using a tubeless booster is to use a CO2 cartridge, gives enough to seat the bead of the tyre on the rim. Care should be taken though to add the sealant after seating the bead though. I've got some on hand for punctures, but regardless unless you plan to inflate a tyre hundreds of times it's a lot cheaper.
