Specialeyes
- Essex
I’ve got both - Cambium all the way for long rides for me. But that’s my arse’s opinion - yours may have other ideas 😀
I'm disappointed to see that no one has taken the "be abusive option".
You big bunch of POOPY HEADS.
You can do it yourself accurately, I've tested it against Fizik's in-shop official measuring system, which is a bench that you crouch onto while you're coached by the fitting assistant. On that bench is a gel pad with a sheet of paper that takes up colour where your bones exert the pressure, then they measure the gap. To do it at home, put a sheet of play-doh or blu tac between two sheets of baking parchment, and put it on something firm like a bench or one of the stairs at home. crouch onto it and lean forward roughly 45 degrees, and wiggle about a little. Measure the two dents centre to centre. I got the same measurement from both systems.After some intense 5 minute research, turns out measuring sit bones is fairly pointless. It will give you the optimal size if you sit bolt upright on a bike, but there are so many variables the only way to reliably get the right fit is trial and error. So the website tells me.
I like Brooks saddles. Had mine for 4 years and it still looks as good as new.
I have heard that the price of them has gone up, but still the best IMHO.
Having said that, they are a bit like marmite and you definitively have to have a Brooks friendly derriere.
I’m going to have hell of a job spreading that on my toast![]()
