Lose weight by cutting down on booze, cutting the size of your portions and giving up crisps, sweets and snacks and eating fruit instead. S'easy.
Nope. That ain't easy
I am struggling to keep my cadence up when climbing. I can now comfortably ride at 80+ rpm on the flat but on a 7% hill in the lowest gear it drops below 60 and I end up grinding. I know it will improve with more riding and I do need to lose weight if I am to climb more effectively. But for now I'm looking to get an easier lowest gear.
I would welcome advice on options or making the gearing easier. My current set up is:-
Chainset Shimano Sora compact 50/34
Cassette Shimano 10 speed 12-30
Thanks for your comments. I agree about the points on losing weight and I am doing that. I've already lost 2st. The challenge is that I'm still 21st.
I think I'm doing pretty well dragging my lardy ar5e up the hills. I was looking for a little more help from the bike while I continue to lose weight.
Here is my last hill ride. 1,200ft of climbing in 12 miles. http://app.strava.com/activities/48041086 I had no problem riding up the hill without stopping. I have the stamina, I'd just like to spin faster to save my legs for the longer runs.
I started riding at the end of September and have ridden nearly 1,600 miles through the winter. I am riding the London 100 in August for Beating Bowel Cancer. As I increase my training I've been told to keep my cadence as high as possible.
I can ride well on the flat. In January I did 50 miles in 3 hrs 40 mins. I now need to do more climbing to get me around the Surrey hills (leith hill and box hill). The next 4 months will be hill climbing sessions in the week with longer weekend rides building to the ride in Aug.
It's a bigger challenge or me than most who will be riding but I will do it within the 9 hr limit. Here is the fundraising page I have recently created in case anyone wants to help motivate me
http://www.justgiving.com/Phil-Lewis-London100
Thanks for all of your help and advice.![]()
Whoops! Please forgive my earlier comment about a "measly 7%". Chapeau to you, sir. FWIW I think you're doing very well on the current set-up, and wouldn't worry too much about grinding up the hills. Stick with the training, you'll probably be at least another 2 stone lighter by August, probably more (in which case you'll probably weigh less than I do) , and you'll look back at this thread and wonder why you ever worried.
Right now I'm slightly teary-eyed - my brother died from bowel cancer, and I miss him deeply. Being outside a bottle of shiraz has made me rather maudlin, so I may indulge in a chaser or two of Speyside malt to see if that helps! Anyway, you now have another donation.
While agreeing that a 34 chainring onto a 30 sprocket should get a reasonably half-fit rider up most hills (let alone the measly 7% that the OP mentioned), I feel duty bound to point out that most of the hills around Merthyr make those around Liverpool pale into insignificance!
Just sayin'!![]()
you clearly didnt read my post !! I was not in anyway having a go at the OP just suggesting he take it one step at a time, oh and I'm not planning an olympic challenge eitherNot all of us are trying for the 2016 Olympics.
My recent 80 mile ride was quite extreme with a couple of 20% hills and some long steep ones.
I got up, like I usually do, but only because I had prior to that ridden it many times with a 24/34 or even 22/34 hybrid gearing.
I have walked up Crawleyside bank in the past only because my road gearing did not suit the terrain. Simply expecting everyone to run before they can walk is, apart from ego, quite illogical.
