ti-raleigh
Regular
- Newcastle upon Tyne
Quick question; the seat post is a modern FWE item which would make it 27.2mm - my eyes could only resolve 27mm on the ruler.
Can I presume that vintage seatposts from 26.8mm and up will fit?
Does this mean the seat tube outside diameter requires a 32mm band-on front derailleur?
Russ
Hi Russ, that's my TI-Raleigh SBDU link you shared earlier. Your frame is from Raleigh's Special Products Division. The 'E' is from 1994 based on what is known about that system. Raleigh had a facility at Nottingham called the 'Lightweight Unit' from 1981 to 1990. That unit used the older and more well known 'W' serial number system, but the unit and the old SBDU were replaced and the Special Products evolved, starting with 'A' numbers in 1990.
If the frame is 531 Competition tubing and uses the standard single butted 531 seat tube then the seat pin diameter will be 27.2mm - the outer tube diameter for a front derailleur should be a standard 28.6mm
Cheers
Neil
