benb said:Rubbish. Fruits generally, and bananas in particular have an exceptionally low glycemic index.
tundragumski said:As a long term goal I really need to investigate further and make a sustainable plan.
eldudino said:I've gone from 20st to just over 13st using www.weightlossresources.co.uk in 18 months. It's been a complete lifestyle change and is the sustainable plan I needed. A couple of other members on here use it too. Good luck on the short term but remember that you need something that will sort out any issues you have with food intake/balance in the long term.
yello said:Depends how you interpret your tables I suspect. I certainly wouldn't say "exceptionally" low. Bananas have high GI for a fruit. Obviously nowhere near as high as sweets etc but certainly not in the low category of beans or lentils for instance. Shall we agree mid-table?
Oh, did you know their GI value increases as they ripen? So I suppose it also depends on what state they're in when you eat them!![]()
tundragumski said:That's an impressive loss. Are there any key points that you could summarise that you feel made the greatest difference?
yello said:I say again, don't be afraid of fat. Don't go switching to skimmed milk just to avoid the fat content of full fat milk. Fat does not make you fat.
tundragumski said:Jwalking straight past the sandwiches in the shop
way to go! There could well be some salads in the sandwich aisle, they might be worth a look. Avoid anything with croutons obviously!
potsy said:I have started buying those small wholemeal loaves instead of normal sized white bread,that way I can still have the same number of slices but much less calories
2lbs off this week too,my loss has started![]()
eldudino said:Cheers. The main benefits have been setting a goal and being given the tools to achieve it. It's quite simple, you get a certain number of cals to put you in a deficit (-500cals from recommended daily intake) then you input your intake from the food database system which has pretty much everything on it (inc. cal, fat, carb etc. content) and it's a case of keeping within that allowance. You get extra calories based on any exercise you do, in order to keep the required calorie deficit.
The other benefits have been that it's online, therefore easy to keep track; it's got a good knowledge base and it doesn't require any meetings/special weigh ins etc. It's given me the understanding of 'get out what you put in'. You have to be self motivated to do it though and support from other family members is helpful too.
