Over The Hill
- Ridden off into the sunset
Hi
Just wanted to voice my support for toe clips. I just have add on type and I think I had to drill the pedal to fit them.
I dont really fancy clipless as you have to then have the special shoes. Unless you are really pushing to knock a second or two off the ride time why bother? Clips do the job and are a low cost solution.
To use them:
First the foot wear - just not too nobbily or thick soled running shoes.
Leading foot is in while stationary - assume no problem there.
If I am pulling out into a busy road or something then I will just ride on the bottom of the pedal until I am going and can ease off to get the second foot in the clip. so no need to rush to get your foot in as you pull away.
Think of the clip as a cup of water and you take a drink of it. Just use your toe to tip it up. So it is a bit of a backwards pressure on the top edge of the pedal when it is hanging upside down.
as you push the lip backwards the pedal should flip round to the right position and you can then just slide your foot in.
Fit needs to be snug but not tight. You end up doing it without thinking in a fairly short time. Perhaps having to look down about one time in ten.
I find I adopt a bit more of a pointed toe position. If you do then you may need to raise the saddle a bit to allow for it as it will shorten the distance a little.
To use them:
