Hi - i bought a specialized hybrid sport disc very recently but i've had a few problems with it and could use some advice, please.
A slight gear change problem and a graunching noise from the rear brake was quickly fixed, but there remains a problem with the front brake.
At first it was binding and the shop fitted some rather Heath-Robinson looking washers between the adapter and the caliper that stopped the rubbing, but left the pads only gripping with about half their area on the disk. Also there was an intermittent loud clacking noise evident when using the brake lever. This happened even when i barely touched it.
I took the bike back and they removed the shims and managed to get the wheel to turn without binding. But the clacking remains (albeit quieter) and this brake now graunches intermittently.
I've also struggled with the shifters. On my old ridgeback i could use the altus shifter without moving my hand on the handlebar grips, but with these acera shifters, i can't reach the upshift lever without sliding my hand along the grip. I've tried moving the unit closer but the downshifter digs into my thumb if i do that.
The shop have been sympathetic and offered to exchange or refund and i'm not sure what to do. I'm a bit fed up with having the brake tweeked and frankly i'm wondering whether they CAN be set up satisfactorily - i believe tektro are not universally admired. And the shifter problem is really irritating - perhaps i was spoilt with the ridgeback.
Can anyone offer a solution that would not involve changing the bike? Or if i did change, what would be a good choice? Should I avoid disk brakes altogether? Apart from the problems, the sirrus is pretty much the sort of bike i'm looking for.
Any constructive comments would be most welcome.
Thanks.
Thanks.
