martint235
Dog on a bike
- Welling
Well that's quite strange. Being the cynic that I am, I was actually expecting the "Helmet and Headphones" vote to be higher, I certainly wasn't expecting it to be 0
You're assuming that headphones completely remove the ability to hear. When I'm cycling I only listen to podcasts or audiobooks and at a low volume. I can still hear cars behind me. I can still hear the sirens of emergency vehicles. I've found listening to something actually helps dampen the sound of a car horn behind me. I can still hear it but I'm not startled by it. In fact headphones help dampen a lot of noise that's further away and not relevant anyway and sudden noises in general are less likely to startle me.. Because there is some hearing lose when using headphones I find I'm more likely to look properly to double check what I'm hearing when making a manoeuvre.It would be ideal if they could however the design of a modern car precludes this and takes it out of the drivers' control. A cyclist with headphones is voluntarily removing a sense. Note the voluntarily as another argument is "But deaf people can cycle" which they can and should do but they don't voluntarily remove the sense and would probably find it laughable that someone would wish to do so.
You meanie! Put it on a speaker and share!Helmet never. Headphones always. It's the only time I get to listen to bangin' hardcore.
