Helmet pad cleaning
Peteaud
South Somerset
The pads in my cycling helmet are a bit dirty and wiffy, what is the best way to clean them?
I dont want to ruin them as i can not seem to find a replacement set anywhere.
WHAT you have to clean them .........:ohmy:
e-rider
Banned member
South West
I bought a brand new genuine GIRO set for £4 so just swapped them all out
400bhp
stick the helmet in a washing machine, inside one of those mesh bags that you put bras/shoes in.
Shut Up Legs
Down Under Member
I use the following:
It consists of 2 velcro strips, one stuck to the inside of the helmet, and the matching strip fastens to the first strip. The strip that I've lifted with my hand in the above picture has 3 strips of window-sealing foam stuck to it (the foam strips have an adhesive backing). This means that when my custom helmet pads wear out, i.e. get flat and less cushioned, I can easily replace them. They're also washable.
I used the above approach, because I found that when wearing the GoPro video camera on the helmet mount, the existing helmet pads weren't soft enough, and so my scalp was hurting, so I used the above solution to increase the padding.
beanzontoast
I wash mine with anti-bacterial handwash, pat them dry with kitchen towel and (in summer) hang the helmet on the washing line for half an hour. In winter it never seems to get that sweaty.
