found some nice black Mishimoto high-torque hose clamps & did a little more work on it
doesn't look to bad ...
inserted thin watery glue & clamped the cut end for a minute, then switched the clamp for 2 wraps of duct tape
the seams seem to be sealed
the back side where I cut the bolt w/ a hacksaw. the clamp got snipped w/ snips, then curled the cut end under so it wouldn't catch on anything & applied a small length of duct tape to seal that edge in. & yeah I see the hole I drilled is not perpendicular to the handle. I rushed & hand held the drilling the slot & the side hole. I often rush & make sloppy mistakes like this. maybe they add character? excuses ...
but I would like a drill press
there just wasn't enough meat above the bolt, at the end of the handle, especially w/ the worm gear placement on the flatter side of the handle. there is no movement. the bolt is snugged up & the JB Weld filler has cured solid
worked well on some weeds
I guess I should have noticed the notch in one blade & used it as a guide for how thick a twig I could cut. whacking at little oak trees, with all my might, using the end of the long original handles as leverage, surely helped damage the handle. we have garden loppers for that. we should not abuse our tools
