Sittingduck
- Somewhere flat
What has been your experience of racking up the miles whilst dropping the pounds? Is low carb a no-no? Should I engage with the tedium that is calorie counting? Should I fast Tuesday and Thursdays? Do I just need to accept feeling hungry all the time?
First of all - good luck! Second of all, I wouldn't personally go with low carb. I have heard it can make you irritable or grumpy if you cut carbs out
I would think it's a case of perhaps re-balancing your intake, to be a bit less carbs, a bit more protein and a lot less booze. This is the approach I took, anyway. I also did/do calorie counting, using myfitnesspal. I found it to be very effective and motivational for me. It also really helped to get the momentum going and to sustain the progress I was making. I believe this is the key - it's mostly in the mind. Once you are in the habit of eating the correct amount of the correct stuff, it almost takes care of itself, on the food front anyway.
RE: the mileage - it certainly hasn't been negative, for me at least. I am definitely able to ride further and a lot faster then before. Oh and the best bit is hills... lovely lovely hills!
Another vote for Myfitnesspal here - counting calories is tedious but it really works, and the phone app makes it really quick and easy. I believe Sitting Duck has lost loads using it (correct me if I'm wrong Ant)
The only thing I have found is that MFP is quite generous with its estimate of exercise calories so I try not eat everything it tells me I've burnt (unless I'm going out that night!).
Yep - I had some good success with it, as Becs said. Realise though that what Greg is looking to do is a little different to me though. I dropped a large amount of weight in a reasonably short amount of time but it sounds like Gregs goals are different.
I also did a lot of stuff at the gym, when I was in massive calorie defecit every day, to try to minimise the amount of muscle loss and increase my lean mass / fat mass ratio. I believe this kind of worked, although I quit the gym due to financial strains! I don't miss weights, as I was doing them purely out of neccessity but I do miss spinning.
I would probably try a number of things and see how it is working out. Obviously everybody is different and have to figure out what is right for them and what doesn't work. These are just suggestions anyway (most of which worked for me)...
Yes - do calorie count. It probably doesn't matter how you do it - just do it.
Buy an electronic food scale for a tenner and weigh everything - at least in the beginning until you can accurately judge stuff.
Cut down on booze.
Lift weights.
Eat more protein.
Still eat carbs but perhaps less (if you already eat a fair bit). Especially stuff like white bread.
Drink more water!
Oh, and I realise I'm probably teaching you to suck eggs here, Greg. Particularly in ref to the weights stuff but thought I might aswell include it for others to see too
