young Ed
see pics further up, of bearings, and all racesCan you post a pic of the head tube and bearing raced. Model and year of bike too.
Scott Speedster 30 from 2009 i think the year is
Cheers Ed
2009 scott speedsterwhat sort of headset bearing am i likely to find in a 2009 scott speedster road bike?
^^^^^^Depends upon how mechanically minded/sympathetic you are to replace these. You ideally need a headset removal 'drift' which you tap with a hammer to knock the race out, but you need to keep it straight. To refit, if you are careful, you can do it with a couple of blocks of wood, and careful taps with a hammer but you must make sure each race is going in straight. Not for the faint hearted. You could of course make a bearing press from a long threaded bolt, big washers and a nut.
http://www.wiggle.co.uk/park-tool-home-mechanic-bearing-cup-press/^^^^^^
This.
@young Ed Even given you youth, I don't think a headset press is a good investment. It is super expensive. Make one as uncle Floissant suggested. Google it, I'm sure there are lots. Your tractor spares box will help, you will need some large washers with small holes. Buy the entire headset with bearings and all.
