According to Specialized my 2010 Tricross has 'Cage bearings integrated HS'
Today I removed the fork to grease the HS bearings as the steering was feeling very stiff, the actual caged ball bearing was pretty much dry and bent so that needs replacing. The piece the caged bearing sits in has cracked, see picture:
What are my options here, can I get a new caged bearing, grease it up, fit it and it'll be fine? Or does it need replacing, if so what do I need exactly?
I need the bike up and running by end of play tomorrow really, luckily I have 2 LBSs which are open tomorrow so should be able to buy bearings but not sure on anything else if it's model specific.
Thanks for any help
Mike
Thanks for any help
Mike
