Hello All,
Following on from my post the other week about my carbon steerer.
I have needed to re-adjust the pre-load on the headset after noticing some play.
With the stem clamp bolts loose I adjust the top cap which sits on top of a 5mm spacer and this is fine I can remove the play no problem.
When I then tighten the stem clamp bolts its as if some play returns. I can if I try just about turn the top spacer by hand above the stem ?.
I cant turn the bottom 15mm spacer below the stem thats rock solid just wondering if the same should apply to the one above the stem as im not sure how I can solve this its a new bike so would have thought everything is in working order ??
Cheers
Cheers
