Head Tube/forks 'locking' into place
As said: I'd go for slightly loose headset, hammered by vibrations. I've written an old threaded headset off on a ride when it came loose and there was nothing I could do but finish the ride. Took it to the shop and they showed me the damage. It surprised me.
NorthernSky
from what has been said i'm sure the vibrations from the car have maybe dented the races then AND stripped grease away
i've maybe accelerated the problem a lot. the bike is a few years old now and the headset has never been regreased or anything
replacement races should be easy to source right?
i don't mind taking to a bike shop if it's a bigger job than i can handle though
Loch side.
It is a small point perhaps, but worthwhile nevertheless to note that these dents are not hammered in but eroded. If you think a bearing can be damaged like that by hammering, try it at home. Wear safety glasses, put the dog away and hammer a ball onto a piece of race. You'll notice that you have to hammer extremely hard just to get a small dent. This dent shows up as a dent caused by displaced material, with a ripple alongside. Headsets wear molecule by molecule that welds and then breaks off.
When hammered, the surface is shiny. When eroded, it has a milky or satin finish.
hi folks
I had my bike in a roof rack. I was doing silly speeds to a sportive I was late for :blush:
well since that I've encountered a strange problem
how do I describe this: if you turn the handle bars, when you get to the centre they seem to jerk and lock into place (straight on)
I can still ride the bike, but you feel it every now and again
what could cause this?
there is nothing obvious on the outside
have I done something to the bearings?
thanks
What sort of speed is 'silly'?
NorthernSky
just took apart there as much as i could, the top race has a split in it, is this correct?
i've put back together and the indexing has pretty much gone, i didn't do anything though :blink:
might need to disassemble again when i get more time
Loch side.
I have a nice little video here of a very indexed headset which I embedded into a PowerPoint presentation some years ago for training our apprentices. However, I can't figure out how to separate the video from the PPT. Obviously Powerpoint just links to the video somewhere else on my hard drive but I can't figure out where or what it is called. Without a name for the video I can't search for that either. If someone is clever with 'putters, I'll reward him/her by posting the video clip.
Milkfloat
An Peanut
Midlands
In PP, right click on the video and go to properties, should show you where it is linked to, but I suspect it is fully embedded which could be a problem.
