Glover Fan
- Almondsbury, Nr Bristol
Err this could be embarrassing and annoying.
Basically my existing 10 speed chain is still reading 12" after 1800 miles, but I have heard that it is good to rotate chains in order to increase the longevity of the cassette and chainrings. So I found myself a bargain 5701 105 chain on CRC the other day for £20. Now i've never fitted a chain before, but I had the instructions with the chain and my trusty Haynes manual to guide me through. I cleaned the chain that I wanted to replace and it turns out it didn't come with a 105 chain as standard even though my bike was advertised as a full 105 groupset it actually has a KMC chain which had the power links, fantastic I thought! Only took me a minute to remove (will definately be buying these in future!!!).
Now I lined the old chain up on the floor and laid the new one next to it so I had the right number of links to install on the bike. Lined up nicely and so like an idiot I jumped in and went to remove the rivet with my Park Tools Chain remover. A lot harder to remove than I thought, but it clicked and it screwed out nicely. Now I may be a bit dense here, but I ended up with two ends exactly the same as like a male to male electrical connection. So I removed a link further which has addressed the problem.
My question is, will 1 link shorter mean I can't use the full range of gears on my bike? Or will some leeway been given when the bike was built?
Also, when removing the second link I somehow managed to slightly bend the outer plate on the chain. I can probably bend it back OKish with some pliers, but will the strength of my chain now be compromised when I put the replacement rivet in?
Thanks in advance.
Jon.
Thanks in advance.
Jon.
