PpPete
- Chandler's Ford
Those cross levers are uglier than suicide levers !
I'm another who prefers to start in the middle and work outwards so as not to have to mess with insulating tape. The annoying thing is when you decide you want the tape starting half inch further out, because you want to fit new bar bag/mapholder/computer/light/GPS and you have to redo the whole tape.
Lost count of the number of times I've re-done the tape on my "best bike".
So much so that on N+1 and +2 I've relented and used insulating tape.
Those in particular or cross levers in general? They are in the shed at the minute so can't look to check, but if I remember right the logo is a bit smaller than on that link,so hopefully won't look too gaudy.
Anyway, the cheapo wheels turned out to have an OLN of 135, not 130 as advertised so sending them back. So what I did was took the old knackered wheel that came with the bike, learnt how to replace a spoke
brasso'd the spokes and cleaned the rim, replaced the tyre and tube and regreased the hub cone bearings. It seems to run fairly true, the wheel is old but has a deor hub, when doing up the cone I couldn't get it past finger tight without it feeling a bit lumpy, so just tightened the outer nut over it and will give it a try. For the front I just used an old wheel that came from the hybrid, it has black spokes so a bit of a mismatch but so long as it rides for now, also a new tube and tyre for this one. The front is 622-19 and the rear is 622-17, with 622-32 Conti City Ride tyres.
