Handlebar Bag fitting issue.
Is it safe?
The bike, the lager, my new filling or the dentist??
Mine is incredibly strong. They are pretty thick extenders. My bike is currently in Norfolk with @hopless500 waiting for me to join it in 15 days as we go off and tour for a month in Europe.
If you ask really nicely Hop may take some better photos of it for you if she can get the bike out of wherever Mr Hop has hidden it.
Anyway i'm woman, that bar bag is the equivalent of my handbag. Take a guess at the weight that extender has to take:laugh:
Don't know that these are any better,but here you are....
shouldbeinbed
Rollin' along
Manchester way
Hi all,
Tried putting my handlebar bag on my touring bike tonight, only to come across this issue. It looks like the bar foam is in the way, but not sure.
Any suggestions?
No suggestions other than an extender as already suggested but shouldn't the bracer piece be under the stem to stop any weight in the bag causing it to droop?
I have a very similar mount, I 'll post a pic shortly to show what I mean.
jhawk
jhawk
Not sure if this makes any difference, but I've taken a picture of my handlebar stem...
Would that make a difference to affixing something to it?
jhawk
jhawk
Also, @shouldbeinbed might I be able to get a couple more pictures of your mounting system, with the bag attached, maybe a wider shot without it, etc? (As I notice that we seem to share a similar handlebar stem design)
Cheers!
jhawk
jhawk
Drill off the mount from the bar bag. Rivet or bolt on a Rixen and Kaul mounting plate and use their extended mount.
Just wondering whether the extended mount that you've linked me to is ONLY the extender, or is it the full Klickfix fitting? If it's only the extender, will I need to purchase the Klickfix fitting item as well as the extender and mounting plate? (Or will the extender be compatible with the fitting that's already on there?)
shouldbeinbed
Rollin' along
Manchester way
Cheers!
My apologies, I must have missed this post at the time: photos attached
Its a Cannondale suspension stem with the lockout lever at the top & suspension at the top of the forks, Older pic of the bike in profile, Suspension bit is obscured by the lock.
From the front and above, bag attached
close in to the bracket, bag removed - this bracket front piece slots onto 2 x U shaped arms that hook around the handlebar and are screwed into from the front piece
riders eye view with the bag attached
(optional) bracer piece that stops the bag slipping - I doubt you'd get enough weight into a bag this size for this to be likely, but it is a useful piece on the Mrs' dutch bike with its wicker basket.
It sounds faffy but it is dead easy in the flesh & was a matter of minutes to fit. No worse that the usual hinged bar gripper types.
jhawk
jhawk
Ah, okay.
I'm just trying to figure out whether I need to buy the Klickfix mount and the 43mm extender, and the mounting plate. Or, just the extender and the mounting plate.
