Yellow Saddle
- Loch side.
That's a good question and the answer is no. A die cuts material away, a rolling head like the one Midlife shows, rolls the threads without removing material. If you cut material, the weakest place on the spoke is where the first thread starts and that's where the spoke will break in time. Not if, but when. By rolling the thread, material is moved around, rather than removed. The first thread is then actually preceded by a small hump of material, which strengthens that area.Out of interest, is a machine necessary to cut the occasional spoke thread? Can't it be done simply just using a die?
Therefore all good spokes have threads rolled on, not cut into.
A machine like the one in Midlife's picture takes about a minute to roll a spoke. A professional machine will do it in one stroke of a lever, which makes a difference if you have to do lots of spokes. For the odd spoke, a rolling die machine like that is just fine.
Should you cut your spoke thread, you'll get a spoke life of less than 1000 kms on a back wheel. With a rolled thread and good building practice, the spoke will never break at the thread, even after 200 000 kms.
This illustration isn't very accurate either, but it makes the point wrt the first thread. A real-life spoke's thread doesn't look like either. It resembles the bottom one but the thread valleys (insides of the V) are rounded. This is to eliminate stress risers.
Here's a photo of a spoke threaded on my Morizumi spoke threader. Notice the rounded valleys and peaks of the thread and the raised bulge where the first thread starts. The scale on the ruler is in millimeters.
The Morizumi spoke cutter and threader.
