Marie Attoinette Fan
Used it once, borrowed some on a Forum ride, did the job on the day but washed off after the ride, I prefer a lube which is more durable, and I can be ready to rush out the door and ride not re-lube.
Also - the chainsaw oil does seem pretty thick so I think it would be a grit magnet if not kept under control. I let it soak in to the rollers of the chain and then wiped off as much as I could from the surface.
I will probably stick with dry lube on my Cannondale which is my good-weather bike.
In your first post Wester, you say the chain seems fine...measure it, if its not wearing, then you're doing ok.
You live in Australia...Chainsaw oil and never clean the chain. It works for me. I wear out wheels and saddles quicker than chains.
I don't think there is a lube on the planet that will stop the chain wearing.
Car auto transmission fluid is ok too- can get it cheap in local car accessory shops Been using it for years in my Motorcycle scott oiler.... far cheaper and works just as well as [scott oiler oil].
