GuyBoden
- Warrington
All I know it that lubrication affects or reduces torque, so you could under tighten. That's
if you use a torque wrench or your guesstimator might be under tightening.
"Dry bolt torque is approximately 30% higher - or 628 lbf ft. If the bolt is lubricated with SAE 30 oil - the torque compared to a dry bolt is reduced with approximately 40%."
