I had read in one place that "as much grease as you would find on a mechanic's hand" was the right amount.Definitely not! It is a interference fit,a hard surface/ soft face , as best has qouted up thread, a good clean, a very light smear of grease then wiped off.
Always I have lightly nipped up, backed of the nut/ bolt, a light tap with a block of wood & mallet on the crank ,then tighted up , being a taper fit gives it the grip, but it can be too tight.
I don't know what caused this problem of mine - overtightening, undertightening...?What would be the symptoms of an overtightened crank bolt? I'm assuming that if you keep tightening it won't actually move the crank any further up the taper?
mahoosive powh !I don't know what caused this problem of mine - overtightening, undertightening...?
Looks like a manufacturing defect to me.I don't know what caused this problem of mine - overtightening, undertightening...?
