I don't get out of the big ring on my compact roadie, but then I do live in Suffolk and we don't have anything remotely hilly round here. If I were tackling mountain terrains day in day out, I may have a different view about gearing.
N+1 (on order) has a standard double 53-39 and 11-26, so I might actually have to start thinking about making use of both chain rings.
That's kind of what I am hoping for - with the status quo as it is the inner ring is a bit neglected. Seems a bit pointless to have one and not use it, hence the move to a double. Not sure I will be spinning out on a 53-11, but always nice to have the option if I do ever find a worthy hill...I use the inner ring on my double a lot. With my old compact, I didn't ever use the small ring except in the hills, this resulted in the big ring wearing out with the inner ring looking almost brand new. Now I have a double, I would say I spend my time probably 50:50 between both rings.
A bit early for innuendo, unless you have been up all night watching Terry Thomas films.'Ring' *snigger*
It sounds very technical but it's not that bad really. The numbers quoted refer to the number of teeth on the gears.thanks for all your comments however as a beginner i dont have a clue when you start talking 53/38 on the front and 12/27 rear. it means nothing to me. if i understand correctly getting a granny ring means changing the gear shifters so is more expensive. now other mention changing gears on the rear which i am having trouble understanding. how to i know what i have got and what i need, all i do know is that i have 8 gear rings on the rear.
Basically the less teeth on the front and more on the back the lower the gear, and likewise the more teeth on the front and less on the back the higher the gear, for instance a 30th front and 28th rear is lower than a 30th front and 26th rear, and a 50th front and rear 11 is higher than 50th front and 13th rear. The number of combinations is bewildering really.thanks for all your comments however as a beginner i dont have a clue when you start talking 53/38 on the front and 12/27 rear. it means nothing to me. if i understand correctly getting a granny ring means changing the gear shifters so is more expensive. now other mention changing gears on the rear which i am having trouble understanding. how to i know what i have got and what i need, all i do know is that i have 8 gear rings on the rear.
The way that gears work is that if you select a small chainring on the front and a large cog on the rear you get an easy gear and vice versa; large front to small rear = a harder gear.
The cassettes are available with a choice of cog sizes so, for example, if you changed from one which ranges from 11 to 25 teeth at the rear to one that is 11 to 28 teeth you'll get an easier gear for climbing. This is a cheap option as usually only the cassette and chain need changing.
Do note though that on a road bike, 28 or 30 teeth is often the biggest you can go on the rear without changing the derailleur mechanism too. (The members on here can advise if you let us know what derailleur you have).
I hope this makes sense.![]()
