Marie Attoinette Fan
Im a demon descender if its a straight dry road with good visibility, if not I'm a descending wuss. Go the speed you feel comfortable with and adapt to the conditions.
This bugged me, so i just did the maths. 30mph is (ignoring air resistance) equivalent to a 9 metre drop, assuming you hit something travelling at that speed. 50mph is a 25metre drop. Sure, both are going to fark you up, but you might easily survive the 9 metre drop. 25 metres, and they will be bringing a body bag.
Just googled, and apparently you are mostly likely to survive a fall with velocity of 12m/s if you don't hit your head. That's 27mph. So there is a lot of difference between 30 and 50mph, if you care about being alive.
This is a 60mph road. Why do you want to block it to other road users and force them to travel at your pace ?Why do you need to pull over if there are cars behind? Just take a more assertive road position, don't need to encourage overtakes at speed
I should add - one of the joys of road cycling as opposed to MTBing is the many, many times you can go as fast downhill as gravity and your legs will let you without having to negotiate trees, roots, rocks and loose surfaces. This might be personal because I'm not massively co-ordinated and find a lot of MTB skills very difficult, whereas on the road bike it's mostly choosing a line and not letting go.
You don't have to be in primary if the road is wide, just not in the gutter. The OP said the side of the road is littered with debrisThis is a 60mph road. Why do you want to block it to other road users and force them to travel at your pace ?
If you were zooming down a hill and a car got in your way at 12 mph [ and intentionally stayed in the way] would you be happy - if so then fine. If not then maybe a rethink. No, cars don't 'own the road - but neither do you.
Yes as I've said. I too have pulled overIn some circumstances this is very good advice but taking it too far puts the rider in alot of danger by annoying car drivers and has the opposite effect, take no risks. Round my way some of the roads are hilly with blind corners and dips making it very hard to pass a cyclist. On these roads i just hop off the road to let drivers past if i am causing a tailback.
Uphill, I'd absolutely agree with you, but if you are going downhill as fast as you deem safe, and as close to the gutter as you dare, and there is a stream of cars behind you, I don't really see what you can do. To stop, you'd need to slow down dramatically, which could be both more annoying and more dangerous. Under those circumstances, I'd glance over my shoulder more than once to let them know I am aware, and wait for the conditions to change so I can pull over safely, clearly indicating my intentions once I have found a safe exit.In some circumstances this is very good advice but taking it too far puts the rider in alot of danger by annoying car drivers and has the opposite effect, take no risks. Round my way some of the roads are hilly with blind corners and dips making it very hard to pass a cyclist. On these roads i just hop off the road to let drivers past if i am causing a tailback.
Because its safer? What does it matter that other road users get held up for a little while?This is a 60mph road. Why do you want to block it to other road users and force them to travel at your pace ?
Lots of times I've been overtaken by cars at the start of a descent, then held up by them as they crawl down. They never pull over and let me past.This is a 60mph road. Why do you want to block it to other road users and force them to travel at your pace ?
