mcshroom
Bionic Subsonic
- Egremont, Cumbria
To be honest I think you will struggle to get anything larger than 28s under the brake calipers. Also making the forks too big will change the geometry and therefore handling of the bike. Having said that, it does look like the pads are well down in your brakes so if you get a similar axle-crown fork with a wider profile then I think 28s should be able to fit.
As mentioned above, Brick Lane Bikes do some, such as this one - https://www.bricklanebikes.co.uk/blb-flat-crown-fork-chrome
This one is a lot cheaper & might work, usually reasonable drop brakes will convert a 27" (630mm) fork to 700c (622mm) - https://hollandbikeshop.com/en-gb/b.../fork-27x-1-1-4-with-2-cushions-chrome-1-inch
As a bit of a curve ball, a tifosi winter carbon fork would also fit and should take 28s, although you would need to switch to a 1 inch threadless headset - https://www.tredz.co.uk/.Tifosi-Carbon-Fork-With-Eyelets_43062.htm
