Gears- when to move front chain ring
snailracer
People are spoilt these days, bikes have ridiculous numbers of gears. If I had to go through all my gears sequencially I'd lose the will to live.
You should avoid the NuVinci hub, then - infinite gears!
Paulus
Barnet,
My first road bike had a single clanger and a five speed block. I got around the country quite well. These days I have a double clanger and a ten speed cassette, I go a bit faster up hills, but that seems to be it.
Bicycle
I work to very simple plans because anything complicated troubles my mind. As follows:
1. I pretty much always start in amiddle-ish gear of the small chainring (only 2 on a road bike, as God decrees).
2. Once I'm up and pedalling, I like to pedal at around 95-100 rpm. So I cog up or down to get there.
3. Much over about 19-20 mph I might whop it onto the bigger chainring.
4. I prefer not to get the chain too crossed, so I avoid where possible running on big/biggest or small/smallest.
5. Getting back out of the big chainring is the funky one; I sometimes don't want to drop that far, so I do 'both thumbs together'.
6. For a short change of gradient, I don't bother changing and just pop up off the saddle.
7. For all the technical wizardry of indexed gears and ergo levers, I often just change to any gear that's 'a bit higher' or 'a bit lower'. It's not very scientific.
8. As long as I'm moving at a decent pace and my knees are moving at a good speed, I figure the gear must be about OK.
9. In my whole life I don't suppose I've gone all the way up or all the way down a set of bicycle gears. I prefer just to go 'click... whirrr... that'll do.'
byegad
NE England
No need to start in the lowest gear, unless your on a steep hill. I used the gear that kept me going at 10mph as an 'on the flat' starting gear and worked up from there. As that was middle front ring and about midway through the cassette it was easy to find it as i stopped too.
dellzeqq
pre-talced and mighty
SW2
the answer to the question is.......before you have to. As in don't wait until the road has turned up before changing down. Anticipate with your front changer, rather than react.
