Sittingduck
- Somewhere flat
Riverman said:Thanks.
I hope I'm not coming across as arrogant. I'm genuinaly curious to get to the bottom of this. I am not a very fit at all, thus I've always assumed I can't be going very fast, even though some of my posts may have given a different impression.
I've sort of got my head around your post MacBludgen. A 7 speed is an interesting proposition. However I think there are two problems
Ideally I'd want the same range as I have (on the top chain ring) now but with a higher gear, but if I wanted that higher gear on a 7speed, wouldn't it mean my lowest gear was higher than the lowest I have now on my top chain ring?
Even though I don't use the lower rings, there are hills round here where I SHOULD use them (eg the map I posted earlier) so I should probably keep them.
Not if you keep the existing cassette and just get a smaller sprocket to replace your current smallest. You could do this on say the highest 2 cogs to give higher gearing. You would need to ensure the remaining cogs/sprockets are in pretty good condition though because a mix of very old and new would cause problems with the chain, I think.
Or buy a whole new cassette (change the chain too) and get one with a larger range - similar large sprocket but smaller at the top end?
