hi, ive been riding my new boardman comp for a few days now and i think its great , but the only thing (apart from the crappy pedals) that im strugling with is the gear ratios. i have 18 speed and under normal riding conditions they are fine, but if there is a relitively steep hill its seems that they dont quite go low enough and its a bit of a struggle.
my question is what is the easiest and cheapest upgrade i can do on the bike? can i just change the largest rear sprocket for a slightly larger one still or do you have to change all of them. also what is the possibility of changing from 18 speed to 27 speed, and if possible will it be very expensive. im not trying to cut corners or be a tight arse, but i have got to watch the pennies after spending nearly £800 over the last week
any advice will be greatly appreciated
thanks
nick
thanks
nick
