Levo-Lon
No but finding a clean northerner would be like wanting unicorns to do it.
.No but finding a clean northerner would be like wanting unicorns to do it.
Good luck with it mate, and I feel for you. Well it's still going well after the new controller but I did notice small particles if white plastic debris in the gearbox.
More research later and it seems they decided to use plastic spring guides on the clutch damper springs (in 20 years I've never seen plastic anywhere near a basket damper...).
So do I chuck another grand at it and 2 days of my time or get shut, chop it in and loose £9k?.
Thinking for my sanity it has to go..
Oooh I really sympathize, that's a tough one.... Just IMHO, plastic should have no place in gear box or engines (I know, I know, someone with greater chemical materials product is probably going to come along and say how resilient plastic is, but I'm a bit old school, and yes, I know some metal alloys can be just as bad). Can't you just keep driving it to see if it holds up? Or are the plastic bits really indicative of upcoming failure?
So can you get replacement better spring guides? Interestingly with the valve body I replaced, there were two types -one type with sleeve guides (OEM) that wore out, and one that were Sonnax built with better guides. At least you know how to do this nowGood luck with it mate, and I feel for you.
You are correct!, plastic should have no place in a gearbox flywheel/ clutch damper.
It will always degrade and break up, no question about it and no arguments from me!.
Or on a timing belt tensioner either. Peanuts saved by the manufacturer at the expense of low mileage belt changes and possible terminal damage to the owner.
Well, it played up slightly on Saturday while I was at work.
Did a TCU reset, Clutch and Shiftpoint learn plus a new filter (300 miles on old one..).
I've bit the bullet and ordered a Stainless Mesh filter (£240 for a fxcking oil filter..), coming from Australia of all places.
The last picture is the plastic guides they expect you to fit back in, bloody joke!.
View attachment 465395 View attachment 465393 View attachment 465394
Is the stainless filter meant to be a superior after-market replacement for the factory one?
I was vaguely thinking about getting a Kuga, and got as far as having a look in a Ford dealer.
A nearly new one is best part of £20,000 - a bit much for me - and the contents of this thread aren't very encouraging.
