Steve Austin said:
GBS, your cranks are fine. crank lengths is one of them often debated cycling red herrings. 175 is fine for most cyclists
simply put:
shorter cranks are easier to spin
longer cranks can give more leverage
any more words will just confuse the issue
As for gearing. You would benefit from 12/28 cassette.
I find this comment a little dismissive.
Crank length is often debated and for cyclists who fall within average dimensions then, yes, 175 will be fine and for those people the topic may, indeed, be a red herring.
However, for those riders who fall outside the normal boundaries, whether tall or short, it is an issue. And the further you fall outside of it the more of an issue it becomes. Of course you can use 175s and live with it, being none the wiser. But why do people spend time and a lot of money perfecting their bike 'fit' or having custom frames built? Because they want to get the greatest possible efficiencies and not taking into account crank length just does not make sense.
For years I used 170 cranks - I never gave it another thought until I tried 175 and found they offered me a noticeable improvement. And now I have much longer ones that even better match my physiology.
I can only repeat my experience of 'fitted' cranks which has been that the benefits are twofold;
First and foremost, comfort. This is a big one (for me, anyway). Long legs simply don't spin as well as shorter legs. I rode a friend's bike recently with 175s and for me that felt like having to walk with a shorter step than normal, if you see what I mean. Not disastrous, obviously, but certainly a lot less comfortable.
Secondly, I believe there to be an efficiency improvement - although this is difficult to measure. I got my long cranks while recovering from illness so any improvement in performance could be attributed to increasing strength, fitness or mechanical efficiency. However, I did find my cassette ratio was then a bit on the 'low' side and changed it for a taller set.
Perhaps I should say that I am a touring cyclist, not a racer.
GBS, you do appear to have longish legs and it is for you to decide whether this is an area that requires further investigation. My opinion is that you would be better served by those with experience of being outside the 'average' rather than accepting a 'one size fits all' mantra.
I've attached a couple of links on this matter that make for interesting reading but there are loads of others if you do a google.com search.
I would say, though, that obtaining non std length cranks won't be cheap so you'll need to be sure it's right for you.
http://www.polaris.net/palmk/Crankset.html
http://www.peterwhitecycles.com/fitting.htm
