Gear Problem. Complete newb, could do with a little help!
Kbrook
There will be an adjuster for the front gears but it will near the top of the down tube. The fact that it one doesn't shift down to the little ring I think suggests that he cable is too tight, but then you say it doesn't shift up suggesting not tight enough. Find the adjuster and give it a tweak.
summerdays
Cycling in the sun
Bristol
You say it's not changing down well at the front- one thing you can do if it's just struggling a little to move down is to depress the lever slightly beyond the point to allow the extra bit to allow it to move not enough to make it shift down the extra gear. Not sure I'm good at explaining that.
And yes as you have worked out avoid big big or small small. When I got my first bike I was told by the shop owner, that I could use gears 1-4 when on the smallest ring, I think it was 2-6 on the middle ring, and 5-7 on the big ring. I would say listen for the rubbing sound and work out which combinations work on your bike.
