Hi all
First time trying to index my gears earlier and even though it looked very simple in the instruction videos, I've made a mess of it (typical...!)
Mid-procedure, my barrel adjuster just seemed to be turning without doing much so I decided to reset everything by disconnecting the cable, turning the barrel adjuster in the full way, and then tightening up the cable bolt again. I was in the smallest cog at this point (as instructed), but then when I started testing it out again, found I could only get into a few of the gears with the shifter. The barrel adjuster helped me access 1 or 2 more, but at this point I thought something wasn't right if I needed to use the barrel adjuster to access half the cassette. So I redid the whole thing again: undoing the cable bolt, turning the adjuster in again, etc. but now when it's all set up again I can't even get out of the smallest cog. The shifter won't press in at all (as if I've reached the other end of the cassette).
Any thoughts on what this could be? I'm a newbie so have probably made some rather obvious oversight.
My feeling is that it's the barrel adjuster, it's very difficult to know if it's working or not (it's a Shimano ultegra one - I saw other online users saying they were having trouble with the specific Ultegra cheap plastic version I seem to have too...) But equally it could be anything...any ideas?
Thanks!
Thanks!
