Onthedrops
- Yorksha
Some of you may have read that I went out for a night ride tonight. A short spin, mainly trying to get used to my new TB3
A complete newbie to road cycling and have never used the combi brake lever/shifters before.
My question, which I hope some of you may be able to answer is:
When changing gear, do you flick the lever over and hold until the change is made? I was just flicking across and found that the gears didn't seem to be meshing properly. Found the chain to be slipping now and again, especially when pressure put on the pedals. On the small front ring and large rear - no problem. Small front and drop it down one on the back - clickety clickety CLANG, clickety clickety clickety clickety CLANG! Frightened the hell out of me. Best description I can give!
The bike is brand new and has done very little mileage so don't suspect cable stretch as yet. Could it be that the derailleur requires setting up better? A bit clueless at the moment
